Hesitation problem
Old 10-21-2010, 11:04 AM
THE MASTER 1's Avatar
Question Hesitation problem
As long as im driving on the streets im fine.....when i hit the highway cruising at 55,60,65 mph etc..... Sumtimes when i nail it....its tends to bog...then it'll catch, then sumtimes it will bog again...then catch an go....otherwords may bog once and go or maybe twice and go....then runs strong....its a 2002 z28....all stock wit 136,000 on tha clock....any ideas??????
Old 10-21-2010, 12:52 PM
tyler.m.13's Avatar
Could be a fuel issue. Maybe a fuel pump or fuel pressure regulator.
Old 10-25-2010, 12:08 PM
JM0523's Avatar
Try a different gas station, maybe they got a bad batch, my car did this til i switched gas stations.
Old 10-25-2010, 04:14 PM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
Are any SES light popping up? You might also check your front O2 sensors and make sure they aren't fouled out. The car will act like what you are describing if those sensors aren't in good working order.
Old 10-25-2010, 04:49 PM
blue98Z's Avatar
Fuel filter still stock as well?
Old 10-26-2010, 12:06 AM
chi-town hustler's Avatar
I've tried different gas, fuel filter is stock and new........but yes ses light is on now and the code was po 0430 and I changed the pass.02 dwnstream sensor, cleared light and two days later, ses light back on......???????
Old 10-27-2010, 10:39 PM
sic2001's Avatar
Id say this is the same issue most are complaining about in different words. A vaccume leak from back behind the manifold usually shows a culprit. Strip back the coating and use a mirror or something to really get a good look, I missed mine for over a year from not stripping and throughly inspecting.
