Water pump woes
Water pump woes
Changed my coolant a couple days ago and my thermostat along with it. Drive it the next day and I have squealing noises come from belts or pulley. I get a flashlight and notice I have drops of water/coolant coming from where the water pump gasket is. Right underneath it in fact. So I figure either my gasket or pump is failing me. My question is, is there any particular brand I should be looking for and where should I get the gasket from? I figure with high mileage I should just replace both and hopefully be done with it. Anything else I should do while i'm in there?
P.S. I already checked the thermostat housing and its not leaking.
The best pump would be a factory pump, but they're expensive.
Or go here to get one..... www.rockauto.com
Go to the dealership for the metal crush type gaskets.
No its not leaking anywhere near the thermostat housing or the thermostat. Its like coming out of the back of the pump. Kinda hard to explain.
LS6247- thats what I needed to know about the gasket.
some of the water pumps i've looked at come with a new O-ring. I am assuming thats actually for the thermostat housing??
Its gonna take to long to get a good pump from rockauto.com, I gotta get this thing fixed 2mrw before it leaves me stranded. I wonder whats better autozone duralast or o"reillys master pro. Both new.
If I was in a rush I'd also just go to one of those places you listed. The o-ring is for the t-stat.
1 Post
u have a 1998 so you have the non o ring style water pump, if it was me i would get it from autozone, lifetime warrenty, it goes bad and you go get another one for free and it will be the new updated sexy looking pump with the o ring seal
Yeah the one from O"reillys has a lifetime warranty as well. + O"reillys will price match to autozones price. As far as which one is better its prolly just luck of the draw.
I need to replace my water pump at some point, and spoke with LM Performance about their pump.
http://www.lmperformance.com/53405/1.html
I believe he said there's a lifetime warranty, but don't quote me on that.
I was thinking about getting that one, then again...I'm in no rush.
Got the pump on today and all is well. Also received my P&P TB in the mail 2day. Gonna put that on 2mrw. Its beautiful. I am running out of cheaper mods to do though. Prolly cut the EGR out of the way while i'm putting the TB on 2mrw.
thanks for everybodys help.
