another powersteering thread
00 ls1 camaro m6. having some issues. i have checked, checked and checked some more. no leaks from under the car. now the reservoir appears to be leaking from the cap. when i look inside while its running. its bubbling pretty bad. i have been just filling it up waiting to see a leak from some where else but no luck. it will last for awhile when i keep the revs low. but im adding every couple weeks. is the pump bad or do i have a air leak somewhere?
I have a 99 z28 and have recently had the mysterious P/S fluid level change also. I used 2 Qt probably over 2 months. Totally out of the blue.
In the mean time I had a water-pump start to go so it had my complete attention not the P/S fluid. While I lined up the water-pump and took time off to replace it about 2 weeks I noticed, gee I havent used any P/S fluid.
Now I know one didn't have an effect on the other, it's just that I was using at least a pint a week at times of fluid and now hardly any. The ONLY thing I did that was unusual is I changed to Walmart standard P/S fluid not any stop leak of any of that crap (blue bottle 2.39 a qt), it was just cheaper and if I was just going to be pissing it away why not. I never use walmart products of any kind before.
So call me crazy, but that's what happened. No doubt this will com back sometime but for now, hey, there is nothing cheap about owning a Z and using factory stuff.
Misery loves company so I will watch to see what happened here. Good luck.
Bob
Orlando, FL
PS
Here in Orlando Florida, Walmart has the best price on real Prestone GM Dex Antifreeze (grey gallon) NOT 50/50, the real deal, $12.00 per gal. Just an FYI.
Bob
Orlando, FL
PS
Save the manuals!
Save the manuals!
Bob
Orlando, FL
PS
Bob
Orlando, FL
PS
thanks that thread had alot of info.
problem found. rack and pinion boot filled with fluid. seal broke.
