removing a/c "HELP"
i deleted my a/c and heat completely. not too hard mainly time consuming. you can do this depending on whether you care about tearing up the plastic box in the engine bay or not. i just drilled a small hole in the box and ripped it apart w/ a punch. for the inside, i removed the dash (there is a good write-up on this site), then capped the heater fittings on the waterpump
