Turning signal issue please help
Ok I hav a 93 z28 Camaro. I'm having an issue with my passenger side front and rear turning signal and brake light. When I put my headlights on everything lights up just fine. but when I push down the brakes I don't have a brake light on passenger side. When I put my right turning signal on I just get a solid green indicator on my dashboard and my turning signals don't work. All of the drivers side light however do work. Can somebody please tell me what my problem is and how to fix it thank you very much.
Also I hav seen people hav this problem only when they're headlights are on but my turning signals or breake light don't work if the headlights are on or off I don't think it has anything to do with my headlights
1 Post
And don't go by the bulbs you pull out, find the correct bulb numbers, as a lot of people end up putting in the wrong bulbs and the problem just occurs shortly thereafter.
