BRAKE, TCS AND ABS INOP all on??
So i got my car running again. I've been really busy with work and never buttoned her up. I put the battery in and i accidently touched the cruise module directly behind the battery to the battery. I started her and she smoked for a bit (prolly cause its been sitting for 3 months) but after a warm up she was sounding good! I looked on my dash and noticed that my lights for the BRAKE, ABS INOP AND TCS are all on!! what did i do? I'm not sure what or how this happened but any thoughts would be great!! Fuse? Wire? NO IDEA what happened.
Thanks guys
Thanks guys
now that i think of it when i did the wire mod i did unplug some sensors around the wheel. When i get home ill check everything it was getting late but it didn't look like any fuses were blown. Any other possibilities? Ive never had a problem like this.
it's either in the wiring or one of the sensors. You don't even have to touch the system and have problems with it. I am removing the TCS and ABS systems and installing a pv.
I am having the same problem in my 01 Z28. Which fuses are you referring to? The ones in the engine bay?
I took the car to a scan and they guy told me I'm having a "ECU malfunction". If the sensors or the fuses are bad will the system throw this code or it is for sure that I need to replace the ABS Module?
