Is there a way to tighten the door seal ??
Save the manuals!
If you take off the wheel well, you can get up to the door hinge bolts. If you push the door in towards the car a bit, it may help - but you'l need to realign the door and fender if you do this. The door is the only adjustment you can do - nothing on the window itself.
The window is completely adjustable, http://shbox.com/1/adj_window.html you can easily tilt it in or any other adjustment you need. I'm not sure why wssix99 posted what he did??????? DO NOT mess with the door hinges!
