passenger door sagging
My car had the same issue when I purchased it, I thought no biggie probably worn out door pins. After inspection door was cracked, not the first camaro I see with cracked doors around the hinge area
1 Post
Door pins usually come with the bushings. Grab a floor jack to support the door, grab a small hammer and punch and knock the pins out. You're probably going to have to remove the door spring on the lower hinge, which you should get the special tool for. I believe Autozone carries them, just ask for a door spring compressor. Then knock out the bushings, tap the new ones in, and tap in the new door pins.
