96 lt1 antifreeze leaking
Old 01-15-2011, 04:04 PM
edobi21's Avatar
Default 96 lt1 antifreeze leaking
Hi, there is antifreeze leaking out of one of the houses going to the radiator or water pump and spraying all over the opti spark and front of the engine. Any suggestions on which house or does anyone have a diagram for the cooling? Thanks
Old 01-16-2011, 05:02 PM
1999maro's Avatar
Which is it, house is leaking or the water pump is cracked?
Old 01-16-2011, 05:08 PM
bigj2717's Avatar
Look at the bottom of the water pump there is a weep hole that coolant will come out when the pump is going bad.
