winning noise when accelerating.
Old 01-17-2011, 08:30 PM
tporto2000ss's Avatar
Default winning noise when accelerating.
I just bought a 2000 ss ms6 with 55k miles on it and when i accelerate i hear a winning noise almost like there a supercharger on it, it stops when i let of the gas or depress the clutch. Any idea?
2000 ss ms6 stock
Old 01-17-2011, 08:39 PM
Greekey's Avatar
Check your exhaust manifold gaskets. I had the same problem and one gasket blew out. Check for carbon deposits around the exhaust manifolds.
Old 01-17-2011, 08:46 PM
babbage1109's Avatar
i get that too on my car its like one of the pulleys is whining? i cant determine which one...
Old 01-17-2011, 08:50 PM
myk
myk's Avatar
Winning noise? It's probably from people cheering you. Seriously, try and get a mechanic's stethescope or a long ratchet/extension combination and try to put it on the motor closest to the pulleys as the car runs. If you need additional room you might do what I did and put the car up on stands and get underneath-do all this while you or a helper works the throttle. Maybe it's a pulley, maybe not, but this should help you determine that possibility...
Old 01-17-2011, 08:52 PM
6speedt/a's Avatar
take the belt off and spin the idler pulley, tensioner pulley, ps pump, alternator, and water pump. btw dont forget about the belt and pulleys for the ac compressor. if they dont spin freely that is more than likely you problem
Old 01-17-2011, 08:56 PM
DownSouthWS6's Avatar
My car just makes losing noises. No but I'd check the pulleys. My A/C compressor does that if I don't have the A/C on. From a distance it almost sounds Procharger-ish (I wish it was).
Old 01-31-2011, 01:21 AM
ToxicWS6's Avatar
does it do it if ur cruisin in what ever gear with clutch out, and u just hit the gas a little it makes it then goes away when let off and stuff? press clutch in goes away even if u rev up? if so its probably rear end related, if it seems to to it strictly engine revs, check alternator, had a k5 that sounded super charged cause my alternator was bad, died on me about a week later, spiking at 18+ volts before dying lol XD
Old 01-31-2011, 08:15 AM
ULTIMATEORANGESS's Avatar
i say its your rear or drivetrain related.
Old 01-31-2011, 10:26 AM
The Mighty Texan's Avatar
Mine was power steering you can check it by having your car in park, on, and turn the wheel all the way to the right and the left. If you hear the sound roward
Old 01-31-2011, 10:27 AM
Mine was power steering you can check it by having your car in park, on, and turn the wheel all the way to the right and the left. If you hear the sound towards the end it is the ps pump
Old 01-31-2011, 01:40 PM
1981turbota's Avatar
mine does the same thing. curious to see results as mines on a ship to germany and cant test it ATM...
Old 02-03-2011, 04:29 PM
diagnosticddt's Avatar
Power steering pump area
check pulley for sure
Old 02-03-2011, 04:34 PM
garygnu's Avatar
throw out bearing.
Old 02-03-2011, 05:26 PM
Yeah the pulleys can deffinatly go bad too, my AC one was so bad that i just took the belt off untill i can repack it.
Old 02-03-2011, 05:44 PM
MisterskeetZ's Avatar
Check power steering pump for leaks and have your rear end/differential looked at.
Old 02-07-2011, 11:37 AM
danbrazda's Avatar
This issue has been driving me nuts for quite some time now. Can't find a vacuum leak anywhere, was able to eliminate all pulleys. Guess I'll be diving into the possibility of an exhaust leak now. Pain in the butt.
Old 02-07-2011, 07:58 PM
sscamaross02's Avatar
i honestly think it could be some wear on gears in your tranny. does it do it just in first? does it go away in second? third? all other gears? if its in all gears it def could be rear end gear whine. where does the noise seem to be coming from?
Old 02-13-2011, 09:11 PM
Bo's 98 TA's Avatar
I have this same prob and I know for sure that its coming from the tranny or shifter and its only when taking off in 1st and reverse, so wouldn't that be a throw out bearing.
Old 02-13-2011, 11:19 PM
Rauch's Avatar
Pilot bearings would squeal until you disengage the clutch. Throwout bearings would squeal when the clutch is disengaged.
Old 02-13-2011, 11:20 PM
BrdOPry's Avatar
Take off the supercharger!
Quick Reply: winning noise when accelerating.
