Replacing front crank seal
Hey everyone, having a hard time here. Just did a cam swap and forgot to replace the front crank seal. But I already have a ARP crank bolt i will use. My question is, can i replace this seal without removing anything if i do it from the bottom? Will a seal puller from one of the autostores (autozone, Oreillys) work to pull the seal without removing the timing cover?
