speedometer not working
Old 04-17-2011, 09:30 AM
00 black ss's Avatar
Default speedometer not working
so all my other gauges are working but not my speedometer. anybody no what is wrong or how i can fix it?
Old 04-17-2011, 05:27 PM
lt1pwr1's Avatar
I would say you probably have an issue with the wiring going to the VSS sensor on the trans. That or an issue with it going to the cluster (rare though). Or an internal issue with the cluster. I would first test the wires going to the VSS.
Old 04-18-2011, 01:49 PM
rabbit320's Avatar
check your fuses on the fusebox inside the door, mine turned out to be the PWR APP fuse...
Old 04-18-2011, 02:35 PM
DAVE00's Avatar
+1 - Check you VSS plug (Green plug on the passenger side of the tranny near the front) and make sure it's fully seated. I bumped mine recently when I was running my racetronix hot wire kit and the speedo stopped worked. Got under there again and reseated the plug and speedo works fine now.
