bad squeaks
bad squeaks
well i have 2 squeaks along with other problems. with the first squeak i think its coming from the rear hatch but i played with a few things and still nothing, i know im not giving alot of info but if you have an idea let me know. second squeak is coming from rear end on both sides, sounds like when u jump on a spring mattress, it happens every time the car hits a bump and when i get out or even if i just push on the rear, im almost positive its either coming from the springs or the arm coming from the frame to the axles, i tried wd40 but idk if im spraying the right spots or if i just need to get new rubber joints. thanks for your time.
I have a solution for both turn up the radio
but for real the first one could possibly be the back seat myn squeaks and drives me crazy the second one I don't know could be anything I had the same problem then one day it stopped lol
