Weird hesitation/misfire at 5k rpm?!
Old 04-30-2011, 02:27 PM
Doubleaction's Avatar
Default Weird hesitation/misfire at 5k rpm?!
Hey guys..I have a 2000 trans am m6 and i just started getting a misfire or hesitation at 5k rpms...The other day i did a pretty nasty burnout and 2 mins after i went to take off, and at 5-5500 rpm it seems to be misfiring or hesitating..there is no check engine light..no weird sounds or anything like i might of screwed up my engine..everything seems normal. I was thinking if it could be just a tune up? Or maybe my clutch is starting to slip at high rpms?
My car is bone stock other than a functioning ram air intake..slp loudmouth and an ls2 clutch.
please help me!
Old 04-30-2011, 11:08 PM
LSwonMatt's Avatar
i had the same prob with my 99 ss under hard acceleration at 5k rpm and at 5500 it cleared up alittle turns out that it was a few of my lifters loseing pressure at high rpm letting the lifters were jumping up and down on the cam which ended up running a grove around the lobes.. i found out for sure when i had my tsp cam installed.. hope this isent whats wrong with your car its not really a cheap fix but it may lead you in the right direction
Old 05-01-2011, 12:38 AM
LS6427's Avatar
Could have bent a valve....that causes misfires, especially at higher rpms.
Old 05-01-2011, 01:28 PM
hmm..it seems to be doing it more when the engine is cold..when the engine is hot it seems to kind of go away a little.
Old 05-06-2011, 11:03 AM
damn i really hope its not a bent valve or lifters..
Quick Reply: Weird hesitation/misfire at 5k rpm?!
