Rattle on accel?
Old 05-04-2011, 12:23 PM
AnnivSS's Avatar
Default Rattle on accel?
So I noticed on the way home for lunch earlier that every time i hit the throttle quick (i.e: accel into traffic, overtake on the highway, etc...) I get a rattling noise from the engine compartment. Its very short and goes away very fast, sounds like a chain running across a gear is the best way I can describe it. Its going into the shop tommorow evening, anyone got any brilliant ideas?
Old 05-04-2011, 02:01 PM
ROCNDAV's Avatar
My 2002 does it too. I read that it could be a heat shield.
Old 05-05-2011, 12:23 PM
DWake's Avatar
Definitely check exhaust components in the engine bay, anything loose or just barely touching the body will make plenty of rattling
Old 05-05-2011, 09:02 PM
joecar's Avatar
Are you sure you're not hearing detonation/knock...?
Old 05-05-2011, 09:05 PM
bad_408_vert's Avatar
^ Its amazing you jump to detonation/knock so quick!
OP your situation sounds alot like the ones described in a thread talking about exhaust heat shields.
