car accelerates son its own!!!!!!
Old 05-06-2011, 07:16 PM
groundZ-28ERO's Avatar
Default car accelerates son its own!!!!!!
my friends o2 z28 likes to accelerate on its own right after he startes it and puts into drive. wtf, i cant figure it out.
Old 05-06-2011, 07:29 PM
zacht's Avatar
really bad brakes???
lol, you need to be more specific...
Old 05-06-2011, 07:32 PM
Sumter's Avatar
High idle?
Old 05-06-2011, 07:34 PM
blitzace12's Avatar
TPS? Tell us more...
Old 05-06-2011, 07:43 PM
you start it put it in D, it gos without pressing the pedal, then when you push the pedal it doesnt accelerate sometimes, then when you let off the gas it wants to by itself, its wierd
maybe dirty maf, or the sensor on the throttle body that calculates how far the throttle is open is ****.
maybe the fuel pump or fuel filter is bad and or dirty
Old 05-07-2011, 03:09 AM
01ssreda4's Avatar
Is the car modded or stock? Whats the idle rpm when its doing this?
Old 05-07-2011, 03:16 AM
jsteele90's Avatar
sounds like a high idle too me
Old 05-07-2011, 09:39 AM
poltergeist 02's Avatar
check the iac see if it's all gunked up.
Old 05-07-2011, 01:03 PM
LS6427's Avatar
There isn't a single electronic part on the car that can open the throttle blade to let more air in. The only way an engine can accelerate without you doing it is if more air gets into the intake than should be there. Therefore, you have a very strange vacuum leak that only leaks when you take your foot off the pedal.......or you need a new IAC valve. As mentioned, it is possible to clean it IF the problem is from the IAC valve being very dirty and its wigging out. Just take it out, don't touch the spring or unscrew it....just spray the **** out of it with MAF cleaner, WD-40, or the like, and bolt it back up to the TB. If it looks clean, go buy a new one and try it out. If it doesn't work take it back for a refund, just tell them it does not fit your TB.
Old 05-07-2011, 01:10 PM
O2Form's Avatar
The cruise control can........ and i heard of a few instances where people claimed the Traction-Cruise control caused the car to accellerate on its own.
Old 05-07-2011, 05:48 PM
ill try and take the iac out and see what that does.
Old 05-07-2011, 07:34 PM
the IAC was filthy dirty, cleaned it and the car runs fine
Old 05-23-2011, 08:32 PM
it was a crushed o2 sensor
Old 11-01-2023, 08:08 PM
2quick4uallday's Avatar
Default what solved it my car is driving on its own
So was it the IAC being cleaned that helped, or was it the crushed 02 senser
Old 11-03-2023, 10:24 AM
bleepster's Avatar
this post is 12 years old dude, and the OP hasn't been on since 2016.
Old 11-03-2023, 10:27 AM
Default can read well
Yeah, I'm totally aware of how old the post is. I'm more hopeful that maybe someone would read it maybe have a response... That's what this is for correct
Old 11-06-2023, 10:23 AM
bleepster's Avatar
are you experienceing the same issue?
Old 11-06-2023, 10:39 AM
Default same problem
Yes,i am.. I unplug the idol air control and it seems to have stopped the issue almost completely. My car has a brand new mass air flow sensor Yet it's throwing a code for it, It's also throwing aTPS code., I found some wires burnt. I believe on the driver side header. I'm not sure where they go to.
Old 11-06-2023, 11:42 AM
bleepster's Avatar
might be beneficial to start your own thread - that may help.
for starters - can you post all the codes you are getting? and replacing/repairing the burned wires is a start.
The following users liked this post:
2quick4uallday (11-06-2023)
Old 01-10-2024, 09:55 PM
98FoRmULa_BiRd's Avatar
I've experienced that on my m6 maybe once or twice. I will notice the idle will be a little higher then it should be and when putting it into gear the car will drive slowly without pressing the gas. I just clean the MAF and throttle body/sensor and it seems to solve it every time. Haven't had to replace anything to date just spray and wipe clean and it seems to go back to normal. Its probably just gunked up.
Quick Reply: car accelerates son its own!!!!!!
