wiper arms please help
Old 05-07-2011, 10:12 PM
chris95lt1ta's Avatar
Default wiper arms please help
When I bout my 95 ta it had the reverse “upside down j hook” connector and I have to fabricate wipers to fit because no one carry these anymore they are discontinued at the dealer. Help on getting rid of these and replacing with normal ones?
Old 05-07-2011, 10:39 PM
1996firebirdformula's Avatar
I just got a Set from Oreilys its a special blade they are 12$ each.
The 93-97 is diff from the 98-02s blades.
I got the ones from walmart they didn't fit almost though they had little tab on inside could grind that down then it would let them swing around.
Rainx does make one that will fit 93-97 but there 18$ each.
You want number 22-24 blade they made for 93-97 Firebird/Camaro Only.
Attached Thumbnails wiper arms please help-sany0101.jpg   wiper arms please help-sany0103.jpg
Old 05-07-2011, 10:51 PM
rbaksi's Avatar
You need 24-9R blades. They are exact fit blades. They're on amazon.
Old 07-21-2011, 06:51 PM
C_Rules's Avatar
do they come with the adapter? also, do two come in a pack?
Old 07-21-2011, 06:59 PM
bigj2717's Avatar
You could always find a set of wiper arms from a newer f-body and put them on so you can run normal blades
Old 07-21-2011, 07:19 PM
C_Rules's Avatar
true but finding the replacement is cheaper and less work. i bought the 24-9r blades on amazon and they were just the rubber part not the whole thing
Old 07-22-2011, 07:37 AM
C_Rules's Avatar
the below picture has the anco 22-24 blades with the adapters. do i need the adapters? do they come with the blades if i just pick them up at the auto parts store?
http://kia-car-parts.macautoparts.ne...500&id=5669530
Quick Reply: wiper arms please help
