Remote Starter Switch Install questions
Old 05-09-2011, 12:10 PM
BadgeZ28's Avatar
Default Remote Starter Switch Install questions
It will make it much easier to adjust my rockers if I have a remote switch attached to the starter motor. My question is what should I do about the coil packs? Do I remove a fuse or fuses or just pull the coil pack connectors? Anything else? Thanks
Old 05-09-2011, 08:14 PM
S10xGN's Avatar
If you connect it to just the starter motor, you'll be bumping the starter with no current going to anything else. No way it'll "start", with the key off all circuits are dead...
Old 05-10-2011, 08:09 AM
Save the manuals!
wssix99's Avatar
Would this work if the car has the key turned to ACCY?
