Oil leak behind timing cover
I've done a lot of searches but im to the point where i just need to start asking questions. Had this over in newbie tech but thought it might be better over here.
My harmonic balancer is wobbling so im going to change it out with a powerbond. I also noticed that i've got an oil leak from behind the timing cover. From what i;ve read im assuming that its leaking from around the crank snout.
Questions, what do i need to order? Here's what i've came up with;
Crank bolt
powerbond harmonic balancer (comes with the crank pulley i assume)
Timing cover seal (not a front cover seal right?)
new belts
Im gonna go ahead and replace the oil pump, timing chain and gears while in there
Melling oil pump (what gasket/o rings will i need?)
LS2 timing chain
New gears (unsure of what brand to go with)
What is the seal called where the crank comes out of the block and into oil pump called? Im assuming thats where my leak is.
Is there anything to replace where the crank contacts the timing cover?
I gotta knock this out at one shot so im trying to prevent any delays for parts. I've already spent more time researching than it should take for the actual job.
Thanks guys
______________
Crank bolt
new belts
LS2 timing chain
Thanks guys
______________
Crank bolt
new belts
LS2 timing chain
Thanks guys
______________
Crank bolt
new belts
LS2 timing chain
Thanks guys
______________
Good luck with your project. Let us know how it goes.
Brad
There is only one seal for the crank. The balancer is the crank pulley and butts up to the oil pump and does not need an internal seal as everything inside the timing cover needs to be covered in oil anyway. The one seal in the timing cover will do the trick.
Also, when I installed my harmonic balancer I put it in the oven to warm it up before install to make it slip right over the shaft. The reason for heating it up is because it is an friction fit and has no key. Once it cools down it will be seated firmly.
**And like Edward Said, Ur gonna need to get a gorilla to torqe down the crank bolt. It is a PITA to torque down! If you have a manual, put it in gear and have at it. If you have an auto, You can try wedging an open ended wrench in between one spoke of the balancer and the k-member to lock it in place while you torque down. That is the method I used and it seemed to work well.
I ordered my welling oil pump, gm timing cover gasket, gm chain, gm oil pump o ring and gm crank seal today. Now just need to find the best deal on a powerbond balancer.
Last dumb question. What temp and how long did you bake your converter?
THats gotta be the weirdest question i've asked this year!
THanks guys! I finally got the info i needed. Also thanks for the heating tip. As far as torq, i've got 2 wrenches that go to 250. The one is about 4 ft long and im hoping i can get it in there.
Also, here is the procedure I used when I did my h/c install. Click Here I realize you are not doing a H/C install, but as far as the timing cover and crank bolt the procedure is the same. If you use the oven method you do not need to torque down the balancer to 240 ft/lbs as that step is to seat the balancer on the hub.
Personally if it were me I would probably at a minimum throw a mild cam in the car while you have it that far apart. It is a matter of taking loose the rockers, cam retainer plate, pulling the old cam out and putting a new one in. Really would only take you an extra 30-45 minutes once you were down as far as taking the timing cover and oil pump off. Just my .02
No damage that i can think of. Whole car just started vibrating one day. After going through the whole driveline and trying 3 sets of wheels and tires along with 3 different tire shops. I just gave up and learned to live with it. One day while tracking down a leak i noticed the pulley was wobbling.
