need help with an AC vacuum line (where to get)
Old 05-27-2011, 09:00 AM
J9_ls1's Avatar
Default need help with an AC vacuum line (where to get)
Can someone help me? I need a hose for this item:
http://www.harborfreight.com/air-vac...ors-96677.html
It goes from the R134 connector to the actual low pressure side of the AC. I need it to not have a check valve or anything, so that I can pull vacuum through it and condition the line so I can refill it. Does anyone have any ideas? Local places would be preferred.
thanks
Old 05-27-2011, 10:35 AM
MrDude_1's Avatar
your local HVAC shop should have a set in stock with gauges.
ive also seen them at some of the better mom and pop auto stores... also with gauges.
btw, I hope you have a large compressor and tank, because while that pump works, its an air hog. It works fine, but it REALLY uses alot of air.
Old 05-27-2011, 03:46 PM
J9_ls1's Avatar
Do you know how much they run? Im trying to stay under 50$
also do you have any suggestions on who I could call?
Old 05-29-2011, 12:09 AM
samson_420's Avatar
Rent a Robin Air evac pump. I use a Blue Point. Real decent unit, but I do this **** often and it is a 350 pump. You should hopefully only need it once.
The local VatoZone's around here rent em'
