Motor oil drip
Motor oil drip
I have a '99 Z with an annoying drip from the back of the motor. It leaves only a drip every couple days but the pan is now a mess. I've looked it over, had it up in the air and hanen't been able to find the source. The only major work on this car is a tranny overhaul. It has almost 130K miles. Any experiences would be a lot of help.
X2 that would be a good place to start, and if you have a hard time finding it, you could try that additive that you put in the oil that makes it look neon when you wear the yellow glasses that come with the kit. If you add that stuff and check it daily it will make any oil leak noticeable enough for you to trace the source of it
