Help!!! Major turn signal problem!!!
Heres the deal just got my first camaro ever (reformed mustang guy lol) and the passenger turn signal will not work. All bulbs are good, left works fine, back passenger signal just lights solid (no flash, and so does the indicator in the dash) when hazards are on all will blink ECEPT for the front passenger bulb. The turn signal wire(blue) is not getting any power but the it will liught as a parking light. I know the bulb is a double filament and that one could be blown so I have tried 4 other bulbs and still no luck the turn sigla wire is not getting any juice at all to it.
Is there a relay or something that could be causing this? could it be the drl module? if so how do I test it?
I replaced the socket because it looked like it was melted and figured the would fix the problem but no luck.
PLEASE HELP!!! dont want to get a ticket or an accident!!!
I think there is a fuse that causes the flasher to actually blink I am not 100% sure so I hope someone else chimes in to help you out with the problem. If not call a chevrolet dealership and ask them.
go to the parts house, by a turn signal relay (or flasher, depending on whats in the system). cost like 7 bucks. replace the flasher (under the dash. remove 2 screws and 2 bolts on the panel below the steering wheel). you will see it on the right side attached to a little dash frame piece with a clip. i just replaced mine and the difference is amazing. no more slow blink/solid light.
Yup...try replacing the flasher under the dash, that fixed my problem a few months ago. Also make sure that every single bulb on the car is working...blown bulbs can make it act pretty weird sometimes
did the flasher and rechecked all the bulbs this morning right after my first post. All bulbs were good and the flasher made my back right signal work fine but the front right still will not flash and I have tried 6 different NEW bulbs to make sure none of the filaments were blown and still nothing.
basically after the flasher my only problem now is that the front right signal will light up but will not flash. This is driving me nuts lol I hate electrical!!!
the issue is with the socket its self. one wire powers the turn signal part, the other the solid light. since I am a cheap ***, I fixed my issue this way. in the socket, there are metal strips that contact the bulb. the issue is that they dont spring out and make contact anymore. so, I clipped the end of a ziptie (the portion that is thin) and shoved it behind the metal strip. this pushed it out enough to recontact the bulb. issue resolved.
its not the socket the socket is brand new and also I checked the blue turn signal wire is not getting power. I traced the wire to right before the driver side headlight and it was not getting any juice at that point.
any other suggestions? about to go nuts lol
I had a problem with my left turn signal working intermittently, and it turns out that apparently a mouse had chewed some wires causing the turn signal and the hazard wires cross.
