Can't hunt down A/C leak
Should be visible using the dye - look at the high side pipe that connects to the condensor, usual spot. Also around the compressor. Oil leaks out as referigerant does, look for that too.
We had a T-bird doing the same thing and the leak was behind the pully for the compressor itself but we couldnt see it even with the dye. We finally used a small hose and could hear it leaking out. Also all the grease and dirt build up on the compressor could have been hiding it.
-Buddy-
-Buddy-
