Bad pulleys?
Old 06-13-2011, 02:59 AM
Cstone812's Avatar
Default Bad pulleys?
So my z28 has been sqeaking at idle on cold starts and sounding like a supercharger when increasing rpms. I know it has to be one of the belts or pulleys but I am not sure. I pulled off my belts tonight and the main serpentine one is pretty glazed. All 3 pulleys spin with no drag and the a/c idler is the worst and is pretty loud so Im thinking that might be it. Just to be sure I ordered all new pulleys (a/c tensioner,idler, and main tensioner, new a/c and serpentine belt and a torx t-50 because I didnt have one to get that a/c idler out) so I am hoping that this will solve the problem. If the pulleys spin with no drag does that mean they are bad? I have read that this means they are going bad and need replaced they all 3 spun a million times with no drag and the a/c idler was the worst and loudest.
Old 06-14-2011, 04:39 AM
02v8ta's Avatar
let mw know if this fixes your problems. Where'd you order from?
Old 06-14-2011, 08:14 AM
BIG_MIKE2005's Avatar
stock idler/tensioner pullies can be pulled off & repacked. Big problem with stock pullies with the age on them now. There is a small notch on the backside you can get a small flathead in & remove the rear seal, repack the bearings with fresh grease & put it back on. Should fix you right up.
Old 06-14-2011, 11:13 AM
02v8ta's Avatar
Which grease is best?
Old 06-14-2011, 11:22 AM
Just grab some good high temp wheel bearing grease from a local parts house & you'll be good to go.
Old 06-15-2011, 04:29 AM
Cstone812's Avatar
I ordered everything from rockauto.com and ill let you know if it fixes the squeak.
Old 06-17-2011, 01:10 PM
Cstone812's Avatar
so i replaced the main tensioner ac tensioner and ac idler pulleys and got a new ac belt and it is quiet as **** now no more annoying squeak!!!!!!!!
Old 06-17-2011, 03:23 PM
If you kept the old pullies & they are in good condition on the surfaces I'd keep them & repack them, that way next time one goes out you have a replacement.
Old 06-17-2011, 03:27 PM
Cstone812's Avatar
Yea I held onto them just incase something happens im just happy that embarrassing squeak is gone.
Old 05-05-2013, 10:08 AM
navyblue02z28's Avatar
How Much did it Cost you to replace your pullys mine is starting to do it.. cant take That Squeaking
Old 05-06-2013, 02:15 PM
dailydriver's Avatar
Was it a squeaking/chirping sound, or a blower-like whine (changing with engine RPMs) that you had originally??
Quick Reply: Bad pulleys?
