wrecked
wrecked
My son crashed my ta on the driver door. now it wont start. i checked the fuses and the fuel and the spark. evrything seems to be ok but it just hits like its gonna start but it wont. also i disconnected the battery to reset com.1999 ls 1 ws6.
when you say he crashed it on the driver door, what exactly do you mean? there's a possibility that he damaged the dash harness, which could possibly create a problem with the bcm/vats
When he wrecked it crushed the rocker panel in. I think that is what you would call it. Its under the door the frame under the door. The dash compartment seems ok but the door wiring harness is messed up,so i may need to unplug it huh.What is bcm/vats? Oh and i forgot one more thing. When he hit it knockedthe rear coil spring off on the right. I didnt know if there is a sensor on the rear to keep it from cranking. Thanks for the info
Is there a kill switch on our cars? A previous car that I had suffered a side impact like that, then wouldn't start, and I finally learned it was due to a kill switch in the trunk. Like I ever would've figured that out...
