help!
Old 06-24-2011, 12:26 PM
T.A.Chick.'s Avatar
Default help!
Well I was driving my car and I noticed a few of my dash lights come on and my stereo was being strange, then my speedometer started to go wayy off, then after that my car started revving itself and it kept jumping forward and finally it shut down. We kept trying to jump it and get it going but it ended up dying shortly after. I called and talk to a mechanic and he said it might be the alternator......I'm trying to do research and read up on this, any ideas what it could be?
Old 06-24-2011, 01:04 PM
crazyc1123's Avatar
Which dashlights were coming on?
Old 06-24-2011, 01:14 PM
sweetride98's Avatar
from what you described i would believe it was your alternator too. did you watch your battery voltage gague? it should be reading above 13 if its below the yellow hash marks it is very safe to say your alternator is not putting out enough juice to charge the battery and run all your accessories.
Good Luck
Old 06-24-2011, 01:19 PM
T.A.Chick.'s Avatar
crazy-the break all i really remember were was the break light.
sweet-im not sure i didn't catch it, but i'm about to charge the batter and see if i can make it to the shop where they can check my alternator.
Old 06-24-2011, 01:42 PM
Starz T/A 17's Avatar
Same thing happened to me and it was b/c my alternator belt broke. So either 1. alternator is bad, 2. Belt broke, 3. Battery is really dead
Old 06-24-2011, 01:45 PM
T.A.Chick.'s Avatar
i just got a new battery in it like in january so i pray to got its just the alternator. are those expensive?
Old 06-24-2011, 02:01 PM
NewLS1Owner's Avatar
They can be. A new one will run about $150-$200 if you do it yourself. Idk how much it'll cost to get it done though.
Old 06-24-2011, 02:04 PM
T.A.Chick.'s Avatar
i can afford anything under $400 over that it might take some time.
Old 06-24-2011, 02:07 PM
yeah. just and idea. try to save up a "rainy day" fund. it'll help say if your engine blows up or if your little brother destroys your transmission...not that i would know or anything.
xRelapse13's Avatar
sounds like the alternator died. Did it start feeling like the car has no power?
Old 06-24-2011, 02:09 PM
sherm6998's Avatar
Might want to look at a used altenator from a truck with a 5.3 from a auto recycler. Cheaper than an LS1 replacement.
https://ls1tech.com/forums/conversio...3-bracket.html
https://ls1tech.com/forums/general-m...need-help.html
Old 06-24-2011, 02:13 PM
T.A.Chick.'s Avatar
newls1-haha, well i don't spend money unless i need to, and i always have a rainy day fund, i knew before buying this car it was nothing but a money vacume.
xrelapse-yes it would revv and then loose power kinda like it was struggling.
sherman-i think id rather buy a brand new one so i won't have to worry about it and it would make me feel more secure.
Old 06-24-2011, 02:16 PM
Arctic2002ss's Avatar
If you buy a new one, get the lifetime warranty. I have replaced mine twice under warranty.
Old 06-24-2011, 02:17 PM
MillerTime85's Avatar
If you can get the car to a shop or a advance auto parts they can test it for you.if not you can bring it in off the car last resort.sounds like your alt. If the battery is fairly new.far as replacement the cheapest would be junkyard or off a member here.
Old 06-24-2011, 02:19 PM
T.A.Chick.'s Avatar
where did you get yours? n how much was it?
Old 06-24-2011, 02:50 PM
ZERO's Avatar
Go to Napa or Advance auto.
Stay away from Autozone's alternators.
Old 06-24-2011, 02:57 PM
T.A.Chick.'s Avatar
okay, well i just took it to get charged and he said itll be about 30 min, then were gonna put it in and see if it is the alternator. i hope it is or something more simple.
Old 06-24-2011, 03:00 PM
cheetoFTW's Avatar
Easy altinator test.... Start car.....while its running disconnect the possitive battery cable. If the car dies the altinator is most likely trashed.
Old 06-24-2011, 03:02 PM
T.A.Chick.'s Avatar
the thing is my car won't even start....
Old 06-24-2011, 03:34 PM
arctic00ws6's Avatar
sounds like your alternator puked and you were running on battery power for a while.
