AC not blowing cold(WTF)
Old 06-24-2011, 05:22 PM
samson_420's Avatar
Default AC not blowing cold(WTF)
I never seen anything like it. This is on a POS Honduh I am building out of random parts.
Here it goes.
I built the AC system, pretty much.
Some decent lines, decent looking compressor, bad dryer, stocker evaporator core, TXV and condenser core.
I evacuated the system for about 45 minutes(held solid vacuum), pumped it with one can then another one.
Nothing, the AC vent temp is 85 degrees.
I added fresh oil to the compressor and blew out the lines before I put it under vacuum.
Pressures are 35-40 & 200-230
I monitored the pressures as added each can. Compressor kicks in and out. Blower motor hums just fine.
Can I get a WTF?
Old 06-24-2011, 05:25 PM
samson_420's Avatar
Oh yeah, fans are on and running at all time the AC is.
Old 06-24-2011, 05:34 PM
GTMLS3's Avatar
You probably have a heater door that will not switch to the cooling mode. With those pressures you should have cool air.
Old 06-24-2011, 08:18 PM
samson_420's Avatar
They seem to be moving just fine. . . It's just cable actuated.
Old 06-25-2011, 07:41 AM
71novaguy's Avatar
I would remove the freon and start again. My guess is there is too much in it, causing the superheat to happen at the wrong time.
Old 06-25-2011, 10:27 AM
samson_420's Avatar
I evacuated the system twice. . . I think the evap core is full of something. I didn't get a good look at it.
But, I think it is.
Old 06-25-2011, 03:02 PM
71novaguy's Avatar
where is the high pressure port at in the system? is it after the evap?
Old 06-25-2011, 03:51 PM
spy2520's Avatar
dryer getting cold? condensation building up?
Old 06-25-2011, 06:55 PM
samson_420's Avatar
Not at all, I am going to have to break it down and start fresh. Damn it. . .
