NEED HELP! Noise coming from either wheel bearing or hub?
Old 06-25-2011, 02:00 AM
camerica's Avatar
Default NEED HELP! Noise coming from either wheel bearing or hub?
Hey everyone, I have a 1999 z28 camaro. I have a strange noise coming from the rear drivers side of the car. Going about 55mph or faster, you can really notice it, it sounds like this, "whomp, whomp, whomp....etc." and it gets faster as you drive faster. If you swerve hard to the right, it gets really loud. If you swerve hard to the left, the sound virtually goes away. I have jacked the rear end up and tried yanking on the tire to see if it had any play, but it doesn't budge. I had it checked out at a major GM dealership in my area, and well... here I am. Thanks!
Old 06-25-2011, 02:01 AM
Ruthless909's Avatar
I have the exact same problem too!
In for an answer aswell
Old 06-25-2011, 09:04 AM
Elthesh's Avatar
My first guess would be tire noise or wheel bearings. If it turns out to be wheel bearings, do both sides. If one side went, how long do you think the other side will last? Plus it's all opened up anyway to do one side, so why not.
How old are the tires though? I had a dry rotted set of rears years ago and they made noise. Even if you know when you got the tires, they could still have been sitting on the shelf a long time. Anyway, easy way to check the date is to look at the sidewall on BOTH sides of the tire. One side will have some numbers like 1111 or 1506. That'll be a date code. 1111 on my tires means 11th week of 2011 is when they were made. They will likely be in an "oval" indentation
Old 06-25-2011, 09:11 AM
Save the manuals!
wssix99's Avatar
I'd start by rotating the front tires to the back and then the back tires to the front, just to eliminate them from the equation.
Old 06-25-2011, 12:34 PM
^^^ I've already tried rotating my tires... Problem is still there
Old 06-25-2011, 01:38 PM
SmokedOutZ28's Avatar
If you swerve hard to the right and it gets louder it's the Left wheel bearing. When you you swerve left it takes the load off that wheel thats why it goes away.
One quick way to verify is have someone spin the wheel by hand and press a screw driver or pry bar on the axle tube leading to that side put your ear to it and listen for the noise.
You could also pull the cover to the diff and make sure there is nothing wrong inside of it.
Old 06-25-2011, 03:54 PM
spy2520's Avatar
I would also double check the front hub bearings because the sound and feel can sometimes be deceiving because of how the car transmits the sound through to body.
Old 06-25-2011, 10:40 PM
elwood2's Avatar
I had the same noise but it was coupled with a bent rim. I knew the rim was bent but i drove on it for a few months because i didn't have the money to fix it. Well, i got a replacement rim and the noise was still there and a little of the vibration also. Long story short, just today i replaced both axle bearings and i also replaced an axle because the bearing ate it up. Get this checked out ASAP or you could end up having to replace the axle also!
Old 06-27-2011, 12:26 AM
camerica's Avatar
Thanks everyone! I will try everything suggested and keep you updated!
Old 06-27-2011, 01:44 AM
camerica's Avatar
http://www.car-stuff.com/1999chevrol...eelbearing.htm
Is there any certain bearing that is better then the other?
Old 06-27-2011, 04:31 AM
elwood2's Avatar
You may need the "repair" bearing which actually moves the location that it rides on the axle. Go to a parts store and ask for it. Timken would be my preferred brand but it's now always available.
Old 06-27-2011, 08:32 AM
Danny2tek's Avatar
Same problem here. And its not the wheels/tires (still have it after wheel/tire change).
Quick Reply: NEED HELP! Noise coming from either wheel bearing or hub?
