abs nopi,security and airbag light on
Old 06-29-2011, 08:54 PM
nug416's Avatar
Default abs nopi,security and airbag light on
As it says ^^. The lights came on while i was on my way home after driving all day without any lights on. Wondering if any one has any ideas. the car is a 94 formula.
Old 06-30-2011, 11:30 AM
Pony Exp.305's Avatar
I have a very similar problem.
ABS,oil, lamp, and airbag light come on while driving makes me CRAZY. After driving for 30-45 minutes, start dies and battery drains. Made me
Had the alternator and the battery (after charging)tested-both tested good.
I did checked all the connectors tightened.
Cause by wet weather or humid?
PCM bad?
Ignition switch Bad?
Old 07-04-2011, 08:59 AM
No help???
Old 07-04-2011, 11:33 AM
bigj2717's Avatar
My abs and airbag light came on and it was just a loose ground. Check the ground post on the passenger fender
