chirping sound coming from the back drivers side
Old 07-01-2011, 02:04 AM
98FoRmULa_BiRd's Avatar
Default chirping sound coming from the back drivers side
Im getitng a weird squeaking sound coming from the back drivers side of the car. Its only when the car is in motion. It literally sounds like a bird chirping and its ironic cuz it is a firebird, Im not sure what it can be. I thought maybe it was the brake pad, then I thought the sound was coming from my drivers side door. Now im just not sure where its coming from. I sprayed wd40 where i thought it might be coming from but still the squeks continue. Its annoying especially when my music is turned down and I am cruising.
Old 07-01-2011, 02:42 AM
UAE_Z28's Avatar
It could be alot of things, if you could get a video and post it , then it'll be much easier to figure out.
Old 07-01-2011, 07:29 AM
99_pewterZ_A4's Avatar
My car has has the same sound for 3yrs.. Just add some longtubes, w/ true duals dumped and you'll never hear the sound again.
Old 07-01-2011, 08:51 AM
Formally Simplɘ Jack
BoricuaHec01's Avatar
I have the same chirp coming from my engine, I just got used to it. But don't know about the chirp coming from your back.
Old 07-01-2011, 09:06 AM
FST SS's Avatar
Mine has a chirping sound too every time I let the clutch out to fast...
Old 07-01-2011, 09:14 AM
udienow's Avatar
I have a squeaking coming from my passanger car rear. Go to your car and push down on that side... does it squeak when the suspension is moving? If not then you know its not suspension related. This is the case for me. I looked further into it down as far as to the e-brake drum thing. I am 90% sure that is what is making my noise. I didnt have time to finish (it got dark) but I am going to rip it apart see if I can figure out what is squeaking with my e-brake. Hope that helps.
Old 07-01-2011, 03:19 PM
StuntmanMike's Avatar
Mine is doign that too...it's kind of a metalic noise, quick, like a chirp, but over and over again...chirp, chirp, chirp... going down the road.
Since it sounds metalic, I'm thinking brakes...maybe the waer indicators on the pads are hitting the rotors.
Prob time to do brakes...I've had the car for just about 4 years and 43k miles, and I've never touched the brakes.
Time to jump on the Brakemotive deal I guess.
Old 05-28-2012, 10:34 PM
cgallagher04's Avatar
Has anyone got a idea what the chirping noise is? I have it in the front driver wheel well. Though it was the brake indicator, got new pads and rotors. Not as bad as it was, but still very annoying !! Please help me . The sound makes me want to punch myself in the face. And Lts and full exhaust do not cover this noise haha
Old 05-29-2012, 08:59 AM
DisasterFormula's Avatar
In the front, it's probably the wheel bearing/hub. They're usually good for about 75K miles.
Old 05-29-2012, 08:11 PM
NVUSZ28's Avatar
The chirp from my car is the struts for my hatch.
Old 05-29-2012, 08:14 PM
metalmilitia606's Avatar
Mine too. My LCA bushings squeak also.
Old 05-29-2012, 08:24 PM
Floorman279's Avatar
my car has the same cricket chirp as well....longtubes and cam and still here it....brand new brakesand rotors and still have it....i think it may be my worn out stock speakers.......
Old 05-30-2012, 11:26 AM
LS14EVR's Avatar
You guys try pulling up on parking brake while driving to see if it goes away?
Old 06-02-2012, 05:32 PM
No but I'll try it . Someone said loosen up something with the ebrake drum
Old 06-04-2012, 11:39 AM
LS14EVR's Avatar
If it goes away when you pull on brake, you have your culprit and you can adjust as necessary.
Old 06-04-2012, 06:23 PM
i pulled ebrake and still there....im telling you guys, its coming from the interior
Old 06-05-2012, 10:42 AM
LS14EVR's Avatar
I get one from under my passenger seat sometimes. You try grabbing that as your driving? Also, maybe fold down rear seat. See if it's the latches. Or spare tire? Just throwing crap out there to check.
Old 06-05-2012, 10:48 AM
Nick V.'s Avatar
its probably suspension. my car does it too. i assume my bearing need to be replaced also.
Old 06-05-2012, 12:13 PM
i considered jack/tire as well
Old 06-05-2012, 12:15 PM
LS14EVR's Avatar
Sometimes the rear hatch makes a chirp too.
Quick Reply: chirping sound coming from the back drivers side
