Part Number Needed - DRL bulb
I noticed that one of my daytime running lights is out, does anyone know the brand or part number so that I can get a replacement?
Also, if any one has experience changing them, how do you replace the bulbs? Does it require removing the bumper?
4008 i think or something similar at your local autozone. They will be able to tell you if you go in and ask. As for replacing it you need to get the car up alittle (the higher the easier on you) and remove the black plastic housing underneath the car. Not the bumper. Remove the air damn, then the bolts to get the other plastic piece you'll see under there, self explanatory once you get under there. Then the bulb housing turns and releases. If your housing is cracked i'd replace it before the sockets become corroded, look at the socket housing while you're down there.
