problem starting help
its 98 ss camaro six speed, I thought it was the starter, but had it tested, and put new starter and did the same thing. the car starts once twice, and three times, then I put the clucth in and nothing, lights gages work but ,does not crank, keep doing this more times then it will start, and starts fine for about five starts, then it all begins the same sequence. help
If this stuff doesn't work, swap your starter relay with one of the fan relays. I just did this and it appears to have fixed the issue. If it continues to be ok, I'll be buying a new relay.
just got back from tune time performance in nj, and he said its the chip in the key, make sure you clean it with alcohol, and if you have to fix it its cheaper to by pass the system.
