Stupid f***ing coolant light....
Old 08-04-2011, 06:53 PM
Blackhawk777's Avatar
Default Stupid f***ing coolant light....
I know I'm not low on coolant, and it's relatively fresh at that rate, but for some reason today my check coolant light came on. Would it be possible it's on if it's a little overfilled? I used that prestone universal stuff to top off what was in there. The bottle claims to work with any coolant. Could that be the problem too?
Old 08-04-2011, 06:54 PM
LS6427's Avatar
Its just the sensor, they go bad all the time. Get a new one.
I think rockauto.com has them.....
Old 08-04-2011, 06:56 PM
LS6427's Avatar
Part # 5S1449 rockauto.com $37.00
amazon.com $47.00...one day shipping available. Part # 5S1449
OR....if you just don't want the light on, you can unplug the sensor.
Old 08-04-2011, 07:07 PM
Where is the sensor located? I'll probably just do that.
Old 08-04-2011, 07:11 PM
LS6427's Avatar
Right under the radiator cap on the back.......the square sensor. Mine has been unplugged for like 7 years.
Old 08-04-2011, 07:12 PM
And the temp gauge still works? If that's the case sign me up!
Old 08-04-2011, 07:14 PM
LS6427's Avatar
Yes, the coolant temp sensor is the brass fitting on the drivers side head right near that front spark plug. They have nothing to do with each other.
Old 08-04-2011, 07:15 PM
Awesome thanks!
Old 08-05-2011, 03:28 AM
myk
myk's Avatar
This just started happening on my LT1; is the sensor the in the same location for those engines also?
Old 08-05-2011, 03:39 AM
oChristiano's Avatar
Yes. Right next to the battery under the cap.
