URGENT PLEASE HELP!!! no power when ignition on
Old 08-07-2011, 03:29 PM
BlackWS666's Avatar
Default URGENT PLEASE HELP!!! no power when ignition on
This seemed to happen overnight because everything was perfect yesterday. Now when i turn my ignition on nothing is getting power, and it makes 2 dings about 2 seconds after turning it on. Like its telling me something is wrong. OBD port is getting no power, everything that is controlled by the ignition is not getting power. Please let me know if you have any ideas or if this sounds familiar. Car is right next to me so i can test your theorys immidiately as they chime in. Thanks guys.
Old 08-07-2011, 03:32 PM
blk/slvr02ss's Avatar
Sounds like A weak Battery or loose cable ?
Old 08-07-2011, 03:36 PM
BlackWS666's Avatar
testing....give me a minute
Old 08-07-2011, 03:39 PM
sneaky7980's Avatar
Check the voltage on your battery if you have a voltmeter handy. Probably dead batt. ANother way to check is get some jumper cables and hook up to another car, wait about 15 seconds and see if you have power.
THere's more you can check but im going to assume you don';t have access to many tools at the moment.
Old 08-07-2011, 03:41 PM
sneaky7980's Avatar
Re read your post. Does your horn and headlights still work?
Old 08-07-2011, 03:43 PM
BlackWS666's Avatar
Nope bat full charged, and all terminals/power links are perfect. anything else?
Old 08-07-2011, 03:44 PM
BlackWS666's Avatar
headlights shine bright as hell. I have a shop full of tools available actually, haha.
Old 08-07-2011, 03:47 PM
Did u take the battery cables off the terminals sometimes there is corrosion behind them or check the fuse box under the hood w/ the main fuses !
BlackWS666's Avatar
Relay for ignition is clicking on, and the 50A fuse is good. Anyone know where the hell the power goes from their?
Old 08-07-2011, 03:48 PM
BlackWS666's Avatar
battery terminals are all brand new, on a brand new battery.
Old 08-07-2011, 03:51 PM
Power should go to the starter from there ! M6 or A4 ?
Old 08-07-2011, 03:53 PM
BlackWS666's Avatar
powerglide. Battery relocation as well.
Old 08-07-2011, 03:55 PM
Neutral saftey switch or the wires to the starter maybe loose !
Old 08-07-2011, 03:57 PM
Insano Z28's Avatar
check your keys chip? Sounds to me like security lock out. A dirty chip or contaminant? Possibly damaged chip?
Old 08-07-2011, 03:58 PM
BlackWS666's Avatar
I have the vats bypass. But i will doubt check it
Old 08-07-2011, 03:59 PM
Insano Z28's Avatar
Ah, nevermind I re read your initial statement. Truly nothing gets power? Accessories?
Old 08-07-2011, 04:05 PM
BlackWS666's Avatar
I have power to the mirrors, headlights, turn signals, windows, things like that. Absolutely nothing to the assessories that should turn on with ignition.
Old 08-07-2011, 04:12 PM
sneaky7980's Avatar
EDITED.
How often do yo use tilt? I use mine everytime I get in and out of the car. I've had wires break in there before.
Also do you have any kind of aftermarket alarms or remte starter?
My initial thought was the vats system that why I asked about the lights and horn.
Old 08-07-2011, 04:16 PM
BlackWS666's Avatar
Originally Posted by sneaky7980
A relay can make noise and still be defectve. I'm not near my car at the moment but can you swap your starter relay? Also do you have any kind of aftermarket alarms or remte starter?
Nope its kind of a race car......kinda. vats is bypassed, i checked it. relay is good, checked it. and all 3 wires coming off the relay are getting full power. SOOOOO it has to be something inside the car.
Old 08-07-2011, 04:23 PM
sneaky7980's Avatar
Edited my last
post. Sorry my phone is slow.
Quick Reply: URGENT PLEASE HELP!!! no power when ignition on
