rounded off oil drain bolt
Old 08-09-2011, 04:56 PM
14k
14k's Avatar
Default rounded off oil drain bolt
whats usually a 10-15 minute job took me 4 hours working on this damn bolt. its extremely rounded off and basically fucked. iv tried vice grips penetrating oil and nothing. its like the previous owner took it in for a oil change and the used an air ratchet to put it back on.
help i need to get this done ASAP.
Old 08-09-2011, 05:02 PM
Element's Avatar
A set of bolt-outs or a torch (just don't hold it there for long) may be your best bet if vise-grips won't move it.
Old 08-09-2011, 05:03 PM
14k
14k's Avatar
vice grips just shaved more off the bolt.
Old 08-09-2011, 05:07 PM
LS6427's Avatar
Dremel...cut a deep channel in the bolt, then use a flat head screwdriver with a ratchet type head and a ratchet to get some leaning force into it. It works like a charm.
If your car is on jack stands or a floor jack...don't push so hard as to knock'em over. Just sayin......
Old 08-09-2011, 05:11 PM
LS6427's Avatar
You can also drill a 1/4 inch deep hole in the center of the bolt head, then tap a larger torx head into it with a hammer. That works too. But you have to really hammer it in there, probably ruin it, but you'll get it out.
Old 08-09-2011, 06:15 PM
14k
14k's Avatar
im not worried about ruining the bolt. ill put a new one in.
Old 08-09-2011, 06:52 PM
89gmcs15's Avatar
try a pipe wrench, like a 10 inch wrench? or maybe weld a crappy bigger wrench to it and then replace it when its out?
Old 08-09-2011, 07:11 PM
LS6427's Avatar
I meant you'll ruin the torx head.....but still, who cares. They're $3.00.
Old 08-09-2011, 07:57 PM
LS_Canuck's Avatar
I've had good success with hammering on a smaller socket.
Old 08-09-2011, 08:01 PM
ULTIMATEORANGESS's Avatar
or if he can get some type of extension on his ratchet like a pipe for extra prying leverage.
Old 08-09-2011, 11:43 PM
89gmcs15's Avatar
oh it seemed to me that the bolt head was too rounded off to even get a wrench on? either way there should be no reason a drain plug should be that tight. sucky deal for the op
Old 08-10-2011, 12:29 AM
parks450's Avatar
Bolt outs from irwin are awesome. I bought both sets with all the sizes just because they saved me that much money. Ive used them many times on other vehicles, I know advance sells them. They have no problem taking rounded bolts out.
Old 08-10-2011, 03:12 AM
myk
myk's Avatar
Lol, they're so awesome they make me wanna dance:
http://www.youtube.com/watch?v=wu460qIEdMs
Old 08-10-2011, 09:10 AM
t/a98's Avatar
ive used craftsman bolt outs on a bolt that was machined into a circle, no flats at all and it gripped and broke it right loose, they really do work. but the irwin looks very similar, get whatevers easiest. i know craftsman has a few styles like lo profile, incase your headers are like my headers. mine are too close to get a ratchet on my bolt so i have to use a wrench
Old 08-10-2011, 02:53 PM
1 FMF's Avatar
get a grinder and grind two flat spots on the head of the bolt so the vice-grip will have a nice flat and decent amount of surface area to clamp down on.
