Trans oil leak
Trans oil leak
I have a trans oil leak on my 97 SS. I thought it was the trans pan, but I put a new seal on and now I see it's leaking from the bell housing/converter area. It's still possible that it's leaking from the pan onto the area between the trans pan and oil pan, but unlikely. Any idea what seal I'm going to have to replace to fix the problem?
Are you sure its transmission oil? My car leaks too, but engine oil and its all over the transmission pan and crossmember. I still am not sure what exactly is causing the leak. I can see oil coming from the top rear of the block. I want to add the leak detector dye to see where the hell its leaking from.
