**Changed my differential oil today... PICS
Old 08-13-2011, 01:10 AM
eddieY87's Avatar
Default **Changed my differential oil today... PICS
Thats all
changed my diff oil for the first time 54k miles
the old oil was quite foamy (pics) anyone know why??
I replaced it with mobil 1 gear oil and a bottle of the GM additive
$8.99 x2 and $13 (dealer ripoff) and a 4$ gasket
Didn't really feel a huge difference YET
anyway here are pics
can anyone confirm if this is a posi/limited slip diff ??
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 08-13-2011, 01:17 AM
AwsmGy's Avatar
I've been getting ready to do mine as well. How long did it take you?
Old 08-13-2011, 01:25 AM
eddieY87's Avatar
to be honest, it probably took me like 3 hours Lol
thats only bc it was my first time, so i took my sweet time making sure i didnt F anything up haha
I made sure to clean everything real good and even painted the bracket that covers the top part of the differential
so it probably shouldn't take you that long
it was pretty simple to do too, I'm not very mechanically inclined but i was still able to so it so, yea
Old 08-13-2011, 05:25 AM
WarShrike's Avatar
Looks like it might have had some water contamination.
Old 08-13-2011, 06:07 AM
NC01TA's Avatar
The stink is so bad that I have the dealership do mine. $100 special and they can do it every time. Not sure what that foamy residue is. Mine was surprisingly clean. Smart to change it.
Old 08-13-2011, 09:34 AM
FirstYrLS1Z's Avatar
Yes,it's a Torsen 'posi'.
Old 08-13-2011, 10:39 AM
eddieY87's Avatar
Thats what i have been hearing. Hmm, I have no idea how that could have happened, maybe a bad diff cover? It was kinda banged up when i removed it.
I thought about having the stealership do it, but it would have been $179.99 at my local GM.
I thought it would be a cool learning experience if i did it myself at least once too.
I expected the smell to be much worst. Yea it was fishy, but i've smelled fishier things haha
Thank you. The car was in an accident in 05 before i bought her and i always worried that they switched out the axle. so thank you
Old 08-13-2011, 01:33 PM
'Trust''s Avatar
Moved, may benefit some of the other fbody guys with 10bolts .
Oil gets like that because of heat cycles/air.
Old 08-13-2011, 01:49 PM
01ssreda4's Avatar
That foamy crap is in no way, shape, or form normal. I have never seen that and I have taken apart a lot of rear ends.
Old 08-13-2011, 02:07 PM
LS6427's Avatar
I'm changing my rear axle seals and bearings soon.....I almost bought my new fluids at the dealership. They wanted $45.00 for 3 qrts of 80w90 non-synthetic (Strange requires that) and $14.95 for the GM friction modifier additive.
The same IDENTICAL stuff was sold at Bennet Auto.....all of it for $30.00 total.
50% less.
Old 08-13-2011, 02:28 PM
eddieY87's Avatar
Any idea what could be the cause of it if it's not caused by water contamination or heat/pressure?
I have no clue
50% less.
Good choice Lol.
Damn Stealership try to rip us all off
Old 08-13-2011, 02:44 PM
Element's Avatar
Probably a combination of water and heat. I had an '87 Blazer that saw duty as a "river truck" for a while before I got it, and the oil in both diffs had turned into gray sludge that made normal used diff oil smell good because of the water contamination.
Old 08-13-2011, 06:08 PM
That's MISTER MODERATOR
Paul Bell's Avatar
I'll also say water contamination. There's a vent that allows air in to keep pressures equalized.
If the car has ever been driven through very deep water, it'll get in.
I would say after seeing that, a second fluid change is is needed after a short drive. This will flush out all the contaminated fluid.
Old 08-13-2011, 08:31 PM
AlamoTA's Avatar
Agree that it's water contamination and a second round of fluid change would be best to ensure you get it all out.
Old 08-13-2011, 08:39 PM
crainholio's Avatar
Torsen diffs don't need the friction mod additive. Won't hurt anything having it in there, but serves no purpose.
edit: because the Torsen has no clutch plates...it's a gear drive.
Old 08-13-2011, 08:43 PM
crainholio's Avatar
Check the top of your rear diff case, there should be a vent sticking out of the center section, passenger side near the axle tube. Yours is likely either damaged or missing. Either that or you've been driving through deep puddles repeatedly and water seeped in through the axle tube seals.
Old 08-13-2011, 09:12 PM
wrencher
wrencher's Avatar
GL5 gear oil has an additive package for sheer, temps & anti foaming as a few things they try to fend off.
The additives break down with water heat etc you will get foam.
Old 08-13-2011, 09:16 PM
14k
14k's Avatar
im not knockin what your saying or anything but can you post a comparison picture of a "normal" rear end oil changes?
Old 08-13-2011, 09:31 PM
crainholio's Avatar
Normal hypoid gear lube should be black and smelly. The tan/brown discoloration of the fluid residue is a clear indicator of water contamination. Seen this enough w/ Mercruiser outdrives that had a prop shaft seal fail, the gear lube comes out looking like a chocolate shake.
Old 08-14-2011, 12:56 AM
eddieY87's Avatar
yeah another fluid change soon seems like a good thing to do.
i noticed the diff cover is kinda banged up anyway so i should buy a new one soon too.
Quick Reply: **Changed my differential oil today... PICS
