For those with P0102 code, MAF circuit input low - LS1TECH
Thread Tools Search this Thread
Old 08-16-2011, 09:40 PM   #1
Default For those with P0102 code, MAF circuit input low
Hey everyone. So 2 weeks ago I got an engine light code saying both my o2 sensors were bad. After much trial and error it turned out to be the MAF sensor. I got a replacement remanufactured MAF sensor from NAPA and the light went off for 3 days. The light came on again after 3 days and it had a new code, P0102. I figured the MAF sensor I got was a defect so I exchanged it for a new one. An hour later it came on again with the same code. Took it back in exchange for another new one. Right after I put it in, light came on again, same code. I checked the voltage in the wires, connectors, even probed the PCM and everything was normal. Checked the eng senseor fuse, that was fine too. checked the o2 sensor wiring for a loose or shorted wire, o2's were good too. I was about to give up. I called NAPA and asked for another brand of MAF sensor. He got an original equipment brand of delphi. I came to pick it up, opened the box and said,...."uhh this looks wrong". My stock MAF sensor was aluminum, square, and had a spliter in it. This one was black plastic, round, no spliter, and the sensors to moniter the air were all in a straight line inside, not in a triangle like the original one. It even had a seperate connector on it also. I was about to send it back when I saw a letter attached to the MAF sensor. It said GM had discontinued the original design of the MAF sensor due to many issues with it, and came up with a new design. Apparently the MAF I got is the new version. I plugged it in, reset the ECU, and have driven 100 miles so far with no engine light and engine runs strong and smooth. No more rough idle or bucking or engine light. For people who get this engine code and replace it wth a junkyard maf or a new one with the old design experiance the same engine code shortly after. Make sure you get the new version from delphi. I figured Id help people who had this issue since I researched for weeks and never found a solid solution.
SEFLS1 is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
MAF Sensor/Tuning Help! Won-Ton PCM Diagnostics & Tuning 34 12-22-2015 06:42 PM
Problem, maf no signal out of no where? (FIXED!) 1nverted PCM Diagnostics & Tuning 3 07-18-2013 09:14 AM
trouble code p0102 maf replaced code comes back need help jbro90 General Maintenance & Repairs 9 01-02-2012 02:59 PM
MAF wire length sensitivity? ... other ideas? RocketSSled Cadillac CTS-V 2004-2007 (Gen I) 4 11-24-2009 05:50 PM
Help me with this code P0131!! Phase1GSR PCM Diagnostics & Tuning 1 05-10-2008 02:14 PM
Tags
circuit, code, error, idle, input, low, ls1tech, maf, o2, p0102, pcm, replacing, rough, sensor, sensors
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
