spark plugs
Old 08-20-2011, 07:12 AM
Bad98SS's Avatar
Default spark plugs
How long will a TR6 plug last? Have 7000 miles on mine and picked up a miss, shows no codes. Trying to figure out if it is plugs or coil pack. Going to change plugs today to see if that is problem if not try coil packs. Motor has good oil pressure no noise just a miss.
Old 08-20-2011, 08:08 AM
Black 99 Bird's Avatar
How good would you say the tune is in your car?
Old 08-20-2011, 08:49 AM
Bad98SS's Avatar
Straightline performance in New lenox ill did the tune got 490 to rear wheels,rus great just picked up a miss. Thought it was vibration problem replaced clutch w/Monster stage 3 started it up thought problem was taken care of let it warm up at idle brought rpm up and it started to vibrate it sounds like it is mssing guess I'll put plus in go from their.
Old 08-22-2011, 09:50 PM
clayp's Avatar
what is your gap? I gapped to .060 on my TR55's and they missed on my 5.3l truck motor. Re-gapped to .045 and the issue was resolved
Old 08-22-2011, 11:01 PM
chrisfrost's Avatar
Ignition missfires can be any # of problems including parts of the engine that are not ignition at all , in other words a miss can happen from lower compression in a cylinder and thats the only problem or multiple prob causing miss .
