I need to replace my oil pan.
Old 08-26-2011, 07:25 PM
02v8ta's Avatar
Default I need to replace my oil pan.
It's dented and looks like it's seeping oil from the drain plug. Is this what I can use?
http://www.summitracing.com/parts/RNB-264-107/
I just want an exactly like stock, just bolt it back up with a new gasket and plug, work fine no troubles oil pan replacement. so^ ?
Also how hard is this going to be? It looks like a bitch. but i was also tired and laying under it with a foot of room at best. Any pointers?
Old 08-26-2011, 09:19 PM
john shea's Avatar
I don't think that is an ls1 oil pan. Can you just replace the oil plug or wrap
some teflon tape around it. I think repacing the oil pan involves jacking the
engine and that pan is not cheap.
Old 08-26-2011, 09:22 PM
02v8ta's Avatar
Need the lt1 But this is a good idea regardless, thanks. The plug is cheap so if that doesn't work oh well. I'll try to get a pic i think the dent runs to where the plug starts and that actually caused the leak.
