engine quit
engine quit
Today I was was getting on it and was doing about 90 and I let off to coast back down to the speed limit and my engine quit, lucky for me I was able to coast home. I did a fuel pressure check and it had no pressure so I changed fuses and still nothing, so ok my pump is shot. I go inside for about 10 mins and decide to see if there is a ses light (my cats are shot so it is always on right now so I cant see if one pops up). so I check for codes but there are no codes (even my cat codes are gone) so I try to start it and it starts right up and it runs fine. I check fuel pressure and it is 60 psi. what would cause this?
So i pulled the pump today, with everything plugged in, but with it outside the tank, i can turn the key on and it does nothing. I can hook the pump upto an external power source and it will spin for about 15 seconds. I replaced the relay and it still does not work. so i am at a lose......
