WHAT window problem is this? (pictures)
Old 08-28-2011, 08:53 PM
02v8ta's Avatar
Default WHAT window problem is this? (pictures)
Motor going out, window off track, fiber glass stripping? The window goes up fine, how ever seems to not seal completely as you can see.
Old 08-28-2011, 09:03 PM
LS6427's Avatar
Will it go up all the way if you pull up on it while pressing the "up" switch...?
Old 08-28-2011, 09:06 PM
02v8ta's Avatar
It will but only while i have my hand pulling up. It wont stay locked up, 100% completely at all.... it'll fall back to that position.
Old 08-28-2011, 09:37 PM
JaYZeig's Avatar
looks like youve got a failing window regulator..id start with taking the door panel off and make sure the regulator is secured and the fiberglass on the door isnt ovaled out (not common)
Old 08-29-2011, 08:08 AM
Save the manuals!
wssix99's Avatar
Odds are that its worse than a regulator. You have to take the door apart to figure out and hope that it isn't this:
https://ls1tech.com/forums/general-m...-included.html
Old 08-29-2011, 09:15 AM
Deviant LS1's Avatar
Most likely the mounting points for the regulator in the door are fubar'd.
Old 08-29-2011, 12:18 PM
1SLwLS1's Avatar
Here's a good video I recorded a week or two ago of my mounting holes being FUBAR
https://ls1tech.com/forums/general-m...or-mounts.html
Old 08-29-2011, 04:29 PM
Duffster's Avatar
Your window tracks are loose OR the mount that rides in the track is loose...
Old 08-29-2011, 04:39 PM
ISMELLRICE's Avatar
i have the same problem i need to fix lol
