Electrical Problems......
Old 08-31-2011, 01:48 PM
Chaos07's Avatar
Default Electrical Problems......
Ok so whenever im driving i notice the volt gauge teeter around 13 and im idle it will drop near the yellow lines. Then when i accelerate it will go back up and teeter around 13.....the alt is practicaly brand new bought it back in april probably. but the battery i replaced when i first got the car back in Feb of 2010. Keep in mind the HEAT here is around 100 easy. Any Ideas what is going on?
Old 08-31-2011, 11:50 PM
Chaos07's Avatar
anybody???
Old 09-01-2011, 08:01 AM
Save the manuals!
wssix99's Avatar
If the voltage goes down with RPMs, either your belt is slipping or your alternator is bad.
What happens when your A/C is off. The A/C will suck a volt or two out of the system, as well. With the A/C off, you shouldn't see any drop at all.
Old 09-01-2011, 10:01 AM
Chaos07's Avatar
when the ac is off it will be about 13v, but at night this wont happen at all it will be a strong 13 - 14 v
Old 09-01-2011, 01:39 PM
Save the manuals!
wssix99's Avatar
You may not have a problem at all, but if you are really on the yellow, checking the belt and alternator is free. (It just takes some elbow grease.)
Old 09-01-2011, 07:18 PM
Chaos07's Avatar
yeah true this morning it was cool around 11, and the needle never moved around 13v but later today around 4 it was hotter and the needle did get below 13v
