car shakes at +55 mph
im not sure what is causing it but sometimes when i driving i say sometimes because its completely random when it happens.
once i get over 55 mph the car will start to shake it will start off as a small shake then get so bad i have to pull the car over. also like im driving on a flat tire.
i think its the brakes cause the pedel feels very hard when pushing on the brakes. when it happens i have to pull the car over and turn the car off for about a min and it stops and i wont have the issue for weeks maybe months.
i have just changed my brake calipers maybe 4 months ago because of the same issue but i guess that didnt fix it.
My steering wheel vibrates and shakes at 54-60 mph then stops. My brakes are kind of hard to push in to. I will probably try to flush the brake fluid and put new in hope that works if thats not it its my calipers but i think its just how the brakes are because im use to driving 2010 and they drive alot better.
im going to try that and also try to change the rotors and brakes as well. i forgot to add to my front left wheel gets ALOT of brake dust on it way more then the other tires even after changing the calipers
My steering wheel vibrate 55+ as well, kinda annoying and shakes worse when I brake at high speeds. I am replacing all 4 rotors + pads this Thursday after chasing this issue since I bought the car.
