turn signal issue *update*
Old 09-05-2011, 04:35 PM
inSSano's Avatar
Default turn signal issue *update*
99 camaro z28
I posted that my fronts wouldn't flash last week. I replaced the flasher and nothing happened. Today I replaced the sockets and the left socket does work and flash now. The right will stay lit but will not flash. I'm not getting the arrow flashing right in the cluster either. Could the problem be a bad ground? The right front not flashing is the only one not working. Let me know your thoughts. Thanks guys.
Old 09-06-2011, 08:13 AM
rjlawlor646's Avatar
try the relay located under your steering column by your right leg. I think they are about 5 bucks at autozone.
Old 09-06-2011, 11:38 AM
inSSano's Avatar
The flasher? If so I replaced it. If there is something else there let me know I'll check it out. Thanks
Old 09-06-2011, 02:13 PM
RedHotG8's Avatar
A relay is different than a flasher. It has contacts inside that are spring loaded.
Old 09-06-2011, 05:53 PM
inSSano's Avatar
alright thanks. I'll check it out.
