A/C blows only through defrost and floor. help
My a/c worked fine and all of a sudden it seems that the vent doors do not move, how is this fixed, vaccum or electric?
Location: Your girl's back door giving her the long stroke while you're at work
If you just put the engine in, check the vacuum line coming off the back of the intake. Should be a T fitting there, one of the lines isn't hooked up
I had the EXACT same problem and it was that vacuum T on the passenger side of the engine compartment......kinda toward the back. That might also be it........parts stores carry those normally. Check that too.
