Water spilling out of reservoir - LS1TECH
Thread Tools Search this Thread
Old 09-08-2011, 10:55 PM   #1
blackhawk98's Avatar
Default Water spilling out of reservoir
When I drive the car around and get it warm and turn it off it starts to bubble then water spills out the reservoir tank. Any idea of what is causing this? Engine doesnt get hot stays around 170 ish
blackhawk98 is offline   Reply With Quote
Old 09-08-2011, 11:17 PM   #2
Coolant boils out of the reservoir tank when air gets into the cooling system. Blown head gasket, bad radiator cap or a leak somewhere is letting air in.....
You need to bleed the system of air before trying to spend money on fixes.
Start the engine when its cold with the radiator cap "off". Let it warm up and watch for the coolant level to drop down, then top it off. Then wait again for the t-stat to open and see if the level drops again. Maybe even a 3rd time.
***While you're waiting for it to heat up the first time...squeeze the upper and lower radiator hoses rapidly and firmly about 30-40 times each....that will move the air bubble by the t-stat if there is one there...
LS6427 is offline   Reply With Quote
Old 09-08-2011, 11:25 PM   #3
I got a new radiator cap, and tried getting air out already, il try to squeeze more though. Thanks
Old 09-08-2011, 11:28 PM   #4
Quote:
You'll know all the air is out....when you see the coolant flowing in the radiator fill neck with the radiator cap "off".......
That means the t-stat has opened. As long as you top it off IMMEDIATELY when the level drops down, you took care of the air bubble issue...if thats even the issue.
If you've been running fine and then all of sudden one day you have coolant boiling over....you have a problem.
Old 09-12-2011, 07:50 PM   #5
Fixed had my lines mixed up
Old 09-13-2011, 09:52 PM   #6
What do you mean which lines mines doing the same ever since I put the motor back in and I didn't hook the lines up my dad did so I was thinking that mabye there crossed
6898camaross is offline   Reply With Quote
Old 11-12-2011, 06:05 PM   #7
Quote:
I had the line from the resevior on the bottom and the line from the heads on top so when engine gets warm the water over flows from resevior.
Old 11-12-2011, 09:30 PM   #8
JaYZeig's Avatar
was gonna ask you about them lines, i did the exact same thing and it drove me nuts for a few days.
JaYZeig is offline   Reply With Quote
Old 11-12-2011, 10:33 PM   #9
beyonddisturbed's Avatar
i came into this thread and knew exactly that it was lines crossed. caused me frustration for a few days once
beyonddisturbed is offline   Reply With Quote
Old 11-13-2011, 01:13 AM   #10
When it first happend to me I thought my trans cooler was leaking.Really embarrassing when you pull up and your car skeets on it self.
Related Topics
Thread Thread Starter Forum Replies Last Post
BOOT HAD LOTS OF FLUID. Help! Rack and Pinion. BirdsOfAFeather Pontiac Firebird 1967-2002 1 05-24-2013 08:08 AM
Methanol leak story and a question :( bboyferal Forced Induction 18 10-10-2007 02:44 PM
<1/2oz a big deal on P1SC ChevyChad Forced Induction 7 02-28-2006 12:43 PM
Rubber Cup in Clutch Reservoir? Nick D Manual Transmission 6 10-14-2004 07:12 AM
LT1 Overheating. Radiator Not circulating (new water pump) koomogee General Maintenance & Repairs 14 05-30-2004 09:52 PM
Tags
94, air, antifreeze, bleeding, camaro, cap, car, coolant, fill, flows, neck, reservoir, spilling, spills, water, z28
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
