lt4 Wont stay running ?? STUMPED !
Old 09-15-2011, 11:04 AM
jmswain's Avatar
Default lt4 Wont stay running ?? STUMPED !
To say the least I am fed up !
1996 Z28 built lt4 6 speed
A week ago I replaced to opti , put everything back together and in the right order . And now I go to start the car , it wont start without the gas pedal being touched . I have to give it gas to start it , and have to keep it above 2,000 rpms , once I bring it down below 2,00 rpm's it wants to die and you can feel and hear a jerking noise . Sometimes back fires ? I know all the spark plugs are in the right order and the opti is set right in the dowell pin .
I am still getting spark and fuel . It did not do this before hand .
The reason I replaced the opti is because I was driving it and the car backfired and died , tried cranking it several times , I had spark and fuel and air . Just would not start , ( this is after the hurricane ) I maybe drove it 10 miles and then this happened. So I replaced it and now it wont stay running .
I hear about VAST Systems , but would this cause this after I replaced the opti ? I am lost and I am trying to sell this car and need help so it will stay running ! I greatly would apprecaite it !
John
Old 09-15-2011, 02:10 PM
96SilverZ's Avatar
First off the gas pedal doesn't do anything when starting the car unless it's at WOT. If you think it's the VATS then check to see if the security light is flashing when you go to start it. If it is the VATS a new key from the dealer might fix it, but you will probably have to bypass it or tune it out.
My car has done what you are describing though. For me it was the coil, alternator, battery, and opti all going bad at once. Since you changed the opti I would recommend checking alternator and battery voltages.
Old 09-15-2011, 03:36 PM
jmswain's Avatar
Since the tune the security light has stayed on, never has caused problems. The battery does need jumped to start it .
With a bad battery or alt would it cause it to jerk and backfire like that ?
Old 09-15-2011, 03:53 PM
87gnx's Avatar
Could you have water in the gasoline? Maybe try some "dry gas" if you think that may be a problem.I know we got ALOT of rain in O.C..
Old 09-15-2011, 04:41 PM
jmswain's Avatar
I am not sure how that would happen , but I might try it !
Old 09-15-2011, 05:38 PM
O2Form's Avatar
Check the cam timing, its possible the chain slipped on the spockets.
Old 09-15-2011, 08:37 PM
96SilverZ's Avatar
Have you scanned it?
Old 09-16-2011, 07:15 AM
jmswain's Avatar
I will have to pull the cover for the cam timing ?
And no I have not scanned it . I dont have anything to scan it with.
Old 09-16-2011, 07:27 AM
robsquikz28's Avatar
Check for codes.
Is your maf plugged in?
Bad opti?
All thses problems occured after ur opti install, so u need to go back over everything and triple check
Old 09-16-2011, 09:43 AM
jmswain's Avatar
Originally Posted by robsquikz28
Check for codes.
Bad opti?
maf is in , opti is new , this just started after the new opti was installed !
Old 09-16-2011, 02:53 PM
O2Form's Avatar
John
Well which is it?
Old 09-17-2011, 08:22 PM
jmswain's Avatar
Originally Posted by O2Form
Well which is it?
What do you mean which is it ?
I am pulling it apart tommorow to check the chain and and teeth !
Old 09-19-2011, 11:25 AM
jmswain's Avatar
Well i pulled everything back off and got down to the opti and it was a crossed wire ! Go figure , also just pulled off my timing chain cover and checked it to be sure , runs great now !
