Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Engine Guides
- Camaro and Firebird How to Replace Battery<br>Step by step instructions for do-it-yourself repairs.
Well my original 10 yr. old battery finally died!
Yep, my original AC Delco battery lasted almost exactly 10 years! Not bad. I always keep it on the battery tender, and just this week I noticed that it kept charging it for a couple of days when normally the light is always green (full charge.) Sure enough I tried to take it to a cruise-in last night and click. Also, the cheap Wal-Mart Everstart battery in my Chevelle is over 6 years old, and batteries in all 4 of our other cars are at least 5 years old. I highly recommend a Battery Tender and I'll skip the outrageously expensive Optima batteries.
Save the manuals!
Battery longevity has to do with chemistry. If you have fewer charge/discharge cycles, the chemicals will stay in better shape and the battery last longer.
Lead acid batteries are also a comodity and (for a traditional design) don't really vary from one brand to another. What matters is the warranty, which should give you a better gauge to the purity of the chemicals/metals inside.
This is probably a low mileage car, right? A battery tender is a good thing if you aren't driving a car very much, but it won't give "life" to a battery.
Save the manuals!
Yea. The originals on the car were good then they had some problems with replacements.
My original lasted a long time and I replaced it with a sealed battery that leaked. That leaking battery was replaced under the pro-rated warranty with a new delco that is unsealed. Its been going strong for several years now.
i had one of those duralast batteries in my beater and that thing didnt even make it a whole year before quitting, tried to charge it and still nothing. OEM batteries somehow ive never had issues with until after they finally crapped out on me after years of good service
LS1Tech Administrator
Received 1,489 Likes
I always get between 5-7 years out of my Delco batteries. They have two different grades for most applications, in terms of warranty. I always buy the better one.
I wouldn't feel comfortable going more than 7 years though. It's a hassle to get stranded due to a bad battery (this has happened to me before), and it's hard on alternators to recharge old batteries that are usually low on voltage at every cold start and eventually begin to resist the charge.
