NEED HELP WITH BRAKES... All caliper pins seized!!!!!
As title says, went to change the rotors and pads the other day and all caliper bracket pins are seized. Wouldn't be a big deal, but they came out a little I guess and now are staggered and can't get calipers back on. Main question is, does anybody have the diameter of the pins? I'm really trying to save some money by just drilling/millling out the old seized pins, but I don't want to drill to big of a hole where the pins would no longer have that suction bond. What size drill bits should I use??
Thanks, just dont feel like paying 130 for 4 new brackets
im not sure if i understand completely, but the pins inside the caliper are sticking out and the caliper + brake pad wont fit the rotor right?? Im not sure what size they are, but did you make sure your e-brake is not on?
yeah one of the pins was out a bit further than the other and caliper wouldnt slip back over the rotor because it was running into the pin sticking out... i dont know why i didn't think about just using the bolt and tightening all the way, i guess i wasn't thinking it was the slip in pins and that it would stop moving once the outside bolt was tightened all the way... i'll give it a try tomorrow, already starting drilling through one tho, but havent gotten all the way through the outside of the pin yet so hopefully i can salvage that bracket... thanks guys
update on the brakes, i guess the rear bracket pins were great, they slid right out and i re-greased um and through on pads and rotors. However, both fronts were seized and i tried moved the pin by tightening the bolt all the way and it just broke the bolt right off. So again, any1 any idea on the size bit i should use to mill these things out?? I'm trying to not have to buy new front brackets, but if worse comes to worse I guess I'll have to.
Very easy to remove the frozen pins, heat the brackets with a heat gun or propane torch until warm. Spray pins with Pb Blaster and let sit for a few mins, then with the bolts installed in the pins tap with a hammer on the ends of the bolts and turn them. I've removed many pins this way.
Yeah I shoulda thot of the torch b4 breaking off the end of the pin lol, o well I got the idea off youtube with a dude on his f150 I believe it was. I'm up to a 5/16s bit now and thrs just a little bit of the pin metal left in the slot. I'm gnna go pick up a set of new pins and just stop drilling once thrs a tight fit on the pin. Hopefully I can salvage these things cuz just realized I prlly gtta change a tensionor pully and maybe even a belt or two
